It is currently Sun Aug 03, 2025 1:44 pm
PostPosted: Fri Nov 02, 2018 11:14 am
First name: Gary
Last Name: Leddington
Anyone have any idea what kind of radius the back of a stauffer / austro-german martin would be?
I have the plan from stew mac but it is not written on it... i can tell it is smaller than 15' as my 15' template does not match up.
Any help would be great.
Best.
G.
www.leddingtonguitars.com
PostPosted: Sun Nov 04, 2018 8:17 pm
I did a quick measurement on a couple of old German guitars from that period. Laying a straight edge across an 11 1/2 inch wide back the gaps on either edge measured about 1/4 inch.
These users thanked the author Clay S. for the post: Fasterthanlight (Tue Nov 06, 2018 3:55 pm)
PostPosted: Tue Nov 06, 2018 3:56 pm
First name: Gary
Thanks... now the question is how to figure out what radius that translates as.
PostPosted: Tue Nov 06, 2018 7:09 pm
If you are less concerned about having a circular curve and go with a spline curve you can just bend a thin batten 1/4 inch below a line drawn through two nails spaced 11 1/2 inches apart. Although it won't tell the radius it will give you a curve that the wood will conform to more easily and minimize problems with end point stiffness.
PostPosted: Wed Nov 07, 2018 11:33 am
Last Name: Lee
Country: Wales U.K.
Using those figures I have just drawn it in Autocad and the measured radius is 1682mm or 66.22" or 5.5ft.
PostPosted: Wed Nov 07, 2018 2:24 pm
First name: Gary
For those interested i found this - https://www.mathopenref.com/arcradius.html
Using this and measurements from the plan i found it to be 8.7ft.
Thanks for the help guys!!
